So, I’m increasingly worried about privacy, and naturally, want to use a VPN. The whole point of a VPN is disguising your IP. But, a lot of services are hard/impossible to use, because of both:
being associated with a public VPN (yeah, you can just keep trying different servers, but thats very fucking annoying to do, and many sites such as wikipedia/netflix/etc fully disallow using VPNs, not just captchas)
not having a static ip (private torrent trackers, you can technically use them its just more annoying)
I’m thinking, is a VPN with a static ip (that is not on the list of IPs associated with VPNs, obviously, if it just get them to keep cycling it until you get one) a good compromise between the two?
No, it won’t stop police from getting your information from the VPN provider/other methods if they really want it, but it would stop things like this, police knocking on the door of 1000 people pirating the EPL or getting takedown notices/lawsuits from companies that just get all of the ips downloading a torrent, or any other number of methods
I’m thinking of the “your house doesn’t need to be totally secure, it just needs to be more secure than your neighbor” theory (idk the actual name of that concept, lol). In a list of 1 million IP addresses, they’ll run them through the register of ISPs to see what ones are at an individual house/the easiest to find the identity of. They’re not going to trawl through each and every IP from the country (I still want good ping so I’d use the nearest server)
Obviously, this is not a good idea if you are an activist, celebrity, politician, etc etc. But if you’re just a “nobody” like me, does this logic still make sense? As I say, its a compromise, but I still think its better than nothing. Browsing the internet unprotected (as I currently am, lol) these days seems like a fucking death trap.
No
That’s not how it works. IPs are registered and owned by companies through their ISP with ARIN.
Static IP’s aren’t necessary for the vast majority of home users. DDNS is your friend.
The point of a VPN is not to disguise your IP.
The point is to create an encrypted tunnel to another network. Location spoofing is just a side effect of that.
It has a static IP. As soon as you log into any of your services, they can associate that IP with you. Now imagine it’s something that uses Trackers, like many programs do these days (telemetry, diagnostics, “anonymous” usage stats etc etc). This meta data would be tied to whatever profiles these big corps have on you and voilà, that static IP is now your meta data linked to you.
My VPN company has 2 levels of static IPs. $2/month for a data center IP and $8/month for residential IP. These are not dedicated.
Each single IP address is allocated to a handful of customers, so your activity can still be “lost in the crowd”.
Hmmmm, I meant like if one of them is flagged as a VPN, just get them to give you a different IP, but it seems from googling that services are blocking entire ranges of IP addresses. Meaning the dedicated IP would be worthless for that purpose. And idk if it’d be that easy to just ask for a different static ip
Would you mind explaining a bit more? How would this solve the netflix/chatgpt/etc problem? Or wouldn’t?
why tf people downvoted you lmao
you gave the best answer to the question. damn this reddit hive mind!
Again, that’s NOT how IPs work. They aren’t just random numbers, just like home addresses aren’t random either. They are all owned and mapped to a location and it’s all public knowledge. If a VPN service wants to provide you a new IP, they need to purchase and register it in a public database. arin.net. It wouldn’t eventually be flagged as a VPN IP, it’s instantly known the moment the provider purchases it - even before assigning it to end users.
Dynamic DNS is a way to assign the domain name to a variable WAN IP address (that’s from your ISP). It involves a provider; some DDNS providers are free, others not. The client (your) side would need some type of DDNS client app, which communicates with the provider, reports the address to them, and they assign that number to the name at the DNS system end. It’s all quite transparent to the user; input a few settings on the client, test, and let it go.
They don’t buy new ones would they? They’d just assign you ones they already own out of their pool of addresses?
I’d meant registered to an owner. The owners details can be masked from the public, but I would assume it’s not a difficult process to obtain for official or legal inquiries.
Interesting what you’ve said about some not owning many or any IPs. I’ll have to read more on that.
If their number of subscribers increased then they would buy more, but they just recycle the same addresses from the same pools, all of which are already known to be associated with the VPN provider.
Yeah, I’m getting it now
really don’t know if there’s any way to get around VPN blockers
You can host your own VPN server, but then you lose protection from authorities, DMCA notices, and anonymity. For torrenting you might use a VPN from a VPN provider, but if you’re trying to simply circumvent VPN blockers that prevent you from viewing content in certain countries, then you could just host your own server. It really depends on the use case and what you’re trying to achieve.
